メインコンテンツにスキップ
Appleがプロフェッショナルおよびパワーユーザー向けに提供するノートPCのラインです。現在、MacBook Proには13、14、15、16、17インチがあり、Pre-unibody(オリジナル)、unibody、Retinaディスプレイ、Touch Bar、SOC(システムオンチップ)設計によって大きな改訂が定義されています。
19993回答 すべてを表示
late 2007 MacBook Pro black screen on boot up.
Greetings to Everyone,
I have a late 2007 17" macbook pro laptop that just died.
Well, it didn't die yet, but the screen is completely black when booting up. I can hear the hardrive spining and the power light is on but nothing on the screen.
Another observation is that the back light on the Apple Logo also does not turn on.
Does anyone know what the problem might be. Is it the screen or the graphics chip. How do I find out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
6件の回答
最も参考になった回答
MacBook Pro: Distorted video or no video issues
Go to : http://support.apple.com/kb/TS2377
An extention (4 years) on the garanty of the NVIDIA GeForce 8600M GT is provided by Apple.
It seems the whole card must be changed, and it's free (see my above link).
Good luck!
  • sorry for my bad english...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
+ agreed, this is a possible Nvidia issue. Hook up to an external monitor and call Apple if it persists.
さんによる
コメントを追加
If the hot-air treatment works, I guess it's because your problem came from use of Lead-Free Solder in manufacturing.
The world electronics assembly industry was forced to switch in mid-2000's from tin/lead solder to Lead-Free (mostly just tin) Solder. That led to many quality problems. Not enough research had been done. Lead-Free Solder is very particular about how it's used and treated, or you end up with bad joints, or short circuits (over time, from tin whiskers). The industry eventually learned, after a few years. Unfortunately, some products made during the mid-to-late-2000's that had passed QC and got shipped out, then failed after some years of use and stress (thermal cycling=turning on/off, humidity, bending, etc.).
Lead-free solder melts around 425 deg-F. But a lower temperature like 300 deg-F can solve problems - relieve stressed joints, close small cracks. This is what the internet videos are doing -- with a hair-dryer or oven.
Tin whiskers is another possible problem. To melt tin whiskers -- each & every one -- you probably need to go to 425 F. That heat could damage certain parts -- battery, aluminum electrolytic capacitors, beepers/buzzes/speakers,... anything with soft plastic. You have to remove these before a heat-treatment.
Instead of high heat, you can take out the circuit board, and use a soft brush and vacuum cleaner to dislodge and suck up the whiskers. Go thru every nook and cranny, especially around the ICs. Be sure to use anti-static tools and work area so you don't 'zap' your electronics. That is, you, the table, and every tool should be grounded.
UPDATE 5-16-16: I had to do the oven treatment twice. (The problem resumed after the first bake, a few days later). The MBP has been working fine now for several months of constant use. But I also did an OS update right after that. The fans run faster now. I'm not sure if I did something wrong in re-assembling it, or maybe Apple purposely tweaked the fan settings for problem-prevention.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thanks for your solution.
I took it to an indepedent apple service place in san francisco and they said that it was the logic board so was not covered under warranty. They recommended that I go to the main apple shop in san francisco and do the following:
1. Be nice to the apple genius bar person
2. Be persistent about the quality of Apple products and how a top quality and top of the line macbook pro should not DIE in just 2 years.
3. Again, be nice and be persistent about quality.
After following the above steps, I was told by the Genius bar representative that it was the logic board but they will repair it for free. After 8 days, I got the laptop back and it's working like a charm.
Thank you very much for everyone's help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem with my Macbook Pro 17, follow those steps, but I live in Mexico, so Apple refuse the service. Top quality product? I dont think so.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
you'll need a small philips head screw driver, a torx T6 screwdriver, some thermal compound, tin foil, and a hair dryer. lol
http://www.youtube.com/watch?v=1jFTi_P24... http://www.youtube.com/watch?v=oMEsexDak...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
2007 MacBook Pro 15 inch. This much loved computer suddenly came up with black screen, normal boot up noises. Extrnal monito port was black as well. Bad video card.
Took it to a "UBreakiFix" shop and they took a week or two to tell me what I already knew and quote me a repair for just a tad more than the puter is worth.
OK, let's harvest that data before recycling it - I ordered a Firewire cable (surprised to find it is rare now) and when that came I hooked it up to my newer notebook in Target Disk Mode. Tip - when you can't see the screen to watch for the Target Disk Mode icon, just hold that T key down for a minute or so - it will eventually show up as an external disk on the Host puter.
So the old unit was sitting on a metal flip top trash can next to my desk while humming along having its data copied over. The next day I checked on things and Video is back in gear! I love that old matte screen.
No ovens, heat guns, solder irons, nothing - just sitting on a trash can lid running a little hot and it seems that some circuit / connection that had opened up was closed again.
So maybe less drastic measure could work for you - a true story.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
rocknroll さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 15,212
