メインコンテンツにスキップ
A children's touch screen smart tablet manufactured by Vtech in 2013.
4回答 すべてを表示
It won't switch on
The innotab will come on for a second then shut down. Have tried replacing the batteries but it doesn't make a difference. Really don't one to buy a new one as my son will grow out of it soon but just need it to last another 6 months or so.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
Please check the following:
If using non rechargeable batteries ensure that they are new.
If using rechargeable batteries ensure that they are fully charged.
That the battery terminals are clean and bright and that they hold the batteries snugly.
That the batteries are inserted with the correct polarity, (see User manual p4).
Try running it on a suitable AC adapter. Just "google" AC adapter for InnoTab 3 to find the right one if you don't have one. The adapter overrides the batteries.
If the AC adapter doesn't make it work and you have tried the above battery checks, unfortunately there is problem with the power circuitry within the unit.
It may be worthwhile to contact an electronics repair centre and get a quote for a repair.
Here is a link to the user manual.
http://www.vtechkids.com/assets/data/pro...
If it turns on and stays on but it is not functioning correctly, here is a link on how to reset the unit.
http://www.vtechkids.com/tutorials/innot...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Clare martin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 2,069
