Why cant I connect to Wi-Fi?
My computer will not allow me connect to the available WI-Fi sources.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hello brittany,
Forget WiFi network and try to reconnect it
Steps --- Copied from Microsoft site ---
"Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
Tap or click Network, tap or click Connections, and then tap or click the connection you want to change.
On the page that appears, make the changes you want"
Restart you Notebook
Re start you notebook and check whether it connected to the WiFi network you select
Windows update
Uninstall last windows update and try to connect WiFi network after restarting the PC. don't forget to reinstall windows update
Hope this answer help you to stay online!
このアンサーは役に立ちましたか?
Hi Brittany,
There may be a few reasons why your Wi-Fi is not working correctly. Visit this trouble shooting page for more information Asus VivoTab RT TF600T Troubleshooting Guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,532
