Why doesn't my replacement digitizer stay on?
My replacement digitizer sticks up above the iPod and won't stay on. Any suggestions? Help would be greatly appreciated.
NOTE! Always remember, this is for reference only. If you are to perform this, make sure that you understand that you are doing this "at your own risk". I am not liable for any damages, injuries and other bad things that may arise from following this.
|| IF YOU DO NOT UNDERSTAND OR UNWILLING TO UNDERSTAND ||
|| THE TERMS AFOREMENTIONED, YOU SHOULD NOT ||
|| PERFORM THIS. RATHER, HAVE THE UNIT SENT TO ||
|| APPLE FOR REPAIR.||
Putting the digitizer back on is a lot easier than removing it. All you have to do is reconnect the digitizer ribbon end back to the it's socket on the green board. Be careful not to pull on the ribbon too much, as you may and up with a broken digitizer again. The proper position of the cable can be seen in the disassembly guide. After finishing the connection, it's time to snap the plastic bezzel of your digitizer back into the iPod touch frame. Place the digitizer ontop of your iPod touch and align it with the body. Refer on the manual for the placement of clips, so that you know where to press on the digitizer to clip it in place. After placing the digitizer back, apply some pressure and run your finger on the digitizer edges so as to ensure that the clips are locked securely.
このアンサーは役に立ちましたか?
also second gen and 3rd gen digitizer cables connectors are different size you have to have the correct one
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,362
3 件のコメント
I would say you never connected it fully or properly
Nick さんによる
Do you know how to connect it fully and properly? Thanks.
Noah Epstein さんによる
iPod Touch 2nd Generation Front Panel Replacement
Nick さんによる
