メインコンテンツにスキップ
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125回答 すべてを表示
What "system" has stopped & can I fix it?
Keeps coming up with :
Unfortunately, system has stopped.
OK
It seems to have added a multitude of games or something. ..some of it looks like !!%@ ....I can't remove anything ...... been trying for 3 days now . I'm terribly technically illerate which doesn't help.
Anyone ?????? Pleeeeeeeassse? ???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
It seems as though malware has taken over your Tab.
Can you operate the Tab at all?
If so try to download, install and run the following:
https://play.google.com/store/apps/detai...
It will check for and remove malware from your Tab. Hopefully this may solve your problem.
If you cannot get to do this try the following:
Before attempting the following ensure that your Tab's battery is fully charged.
You will have to perform a hard reset.
Hard Reset
Warning : Your Tablet will be reset back to factory default, you will lose all user downloaded apps and user data - it will be like when you first bought it.
Ensure the Tab is OFF, then
Press and hold the Volume up button then press and hold the Power button. (two buttons held on together)
When the Samsung logo appears, release all.
Select wipe data/factory reset. (Use the Volume buttons to highlight and the Power button to select.)
Select Yes -- delete all user data. (Use the Volume buttons to highlight and the Power button to select.)
Select reboot system now. (Use the Volume buttons to highlight and the Power button to select.)
Allow several minutes for the reboot process to complete.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
i have this problem too. i already did the factory reset, but "system has stopped" still showing.
さんによる
Hi, Hjay Red,
Try reinstalling the firmware. http://www.samsung.com/ca/support/skp/fa...
さんによる
I'm having the same problem too, I tried the reset but seems like there are so many "Unfortunately stopped errors"
さんによる
コメントを追加
回答を追加する
heathercc さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,767
