Why does my iPad give sound and music through one earphone?
I just replaced my earphone jack and now only gives sound through one earphone. Please someone help!!
The issue is either your headphone or the jack. Try another headphone and see if that helps. If not, then you'll need to replace the headphone jack. Replacing the headphone jack involves removing the digitizer first. If you haven't done this before, then you should have a repair shop do it for you as it is not easy to do this without breaking the digitizer.
このアンサーは役に立ちましたか?
I just replaced the headphone jack so it is new. I dont know what it is.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 59
