メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
iPhone has no mic access or sound at any time, when interacting.
Hey there I have an iPhone 5 that has a fault with the mic and speaker while in a phone call and video's ect.. I have tried changing out all the hardware (put the logic board in a perfect working order iphone5) which made no difference, which suggests its a problem with the logic board or a software problem.
When trying to activate siri I receive a message titled "Built-in Mic Not Active"
Was wandering if anyone had come across this before or knew a fix for this issue.
Cheers,
Chris
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like maybe you have cancelation microphone sensor...2nd mic which is connected to your power/volume flex...if you cancelation mic is damaged or cloged it will cancel out all sounds.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did switch the logic board out from the hardware though, I put it into a perfect working chassis and the problem was still repeatable. This wouldn't be the case if the mic itself was damaged?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 51
