Why wont my GPS charge?
I have my GPS plugged into the charger but it is not charging.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check that the charger is plugged in all the way and the gps should show it's charging. If it doesn't show right away that the gps is charging maybe wait for about ten minutes because the gps may be very dead. Sometimes it needs to be plugged in for a while before it shows that it's charging. If that doesn't work then maybe the charger is defective and you will need to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 292
