メインコンテンツにスキップ
Released July 2012 by Fuhu, Inc. Model Number: NABI2-NV7A.
37回答 すべてを表示
My nabi 2 is showing me " unfortunately, google search has stopped."
how do you clear it off the tab so it can be use again? can't pull the keyboard up to put in wi-fi pass code for internet at me home?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
3 件のコメント
I'm having the same problem... did you get it fixed?
さんによる
さんによる
Did you get it fixed yet???
さんによる
コメントを追加
2件の回答
最も参考になった回答
There is an easy way to fix this if you have not already figured it out.
Update (01/10/2016)
You need an OTG cable that will give you the capability to plug in a wired keyboard to type in your password and get into parents mode. The cable costs anywhere from 1 buck to 3 bucks online. Once in parent mode you need to go to settings. Apps. Select all at the top then find Google search and select it. From there clear all cached and data. Then proceed to enjoy your tablet again!!!!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Ok what is an OTG cable? I am having this same issue and I am not finding anything that helps. Is this something I can buy at a store or do i have to buy it online?
さんによる
Yeah when I try to do it it just says couldn’t sign in to your google account.
さんによる
コメントを追加
How did you get it fixed??
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi,
Have you tried a 'soft' reset' Here's how to do it.
There are two ways you can perform a soft reset: Hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi. Use a small thin object (such as a needle or paperclip) to press the Reset Button located on the back of the nabi.
さんによる
Jayeff, where do you see a reset slot in the back? All I am seeing is one on the bottom and I don't know if I am doing this wrong or if it just isn't working for me.
さんによる
Hi Amy Daigneault,
I was looking online before and found this on the Nabi website https://www.nabitablet.com/support/artic...
さんによる
コメントを追加
回答を追加する
Alfonzo Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 10,414
