Why won't the battery charge?
Whenever I plug the charger into the battery, it won't charge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There are a couple reason why the battery for the camera won't charge. One reason is that the charger itself may not work. If you have an extra battery or another device that uses the same charger, try using the charger with those. If the charger charges the other battery or the other device, that means the battery for your camera is bad and needs to be replaced. If the charger didn't work on the new battery or the other device, then that means the charger is broken and needs to be replaced with one that has the same serial number/ specifications.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,602
