Why is my Garmin Nuvi not holding a charge?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Trey Ulsh, depends on what you have truied. Check the charger and the cable. than check the charging port for any broken bend pins etc. If that looks okay, replace the battery and check the charging port on the circuit board to make sure it makes proper contact. Evaluate after each step to see which remedies, if any, worked.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 196
