Why is my password not working only flashing the light
my password not working only flashing the light why
my id is SAADBAIG267@GMAIL.COM
FB NAME :SAADBAIG
You need WD Smartware. When Passport asks for password put in the wrong password 5 times it will then ask if you want it formatted say yes. Then it will work fine. You will lose all info on the disk but have functioning disk.
このアンサーは役に立ちましたか?
what if i dont want to loose the info on the disk is there a recovery option?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 10,177
my password not working only flashing the light why. and my windows is hang
amar reddy さんによる
Same problem here!!!
Windows 7 stop working.
In my case it look like it's the UBS adapter is not ok...
I move the cable and the light comeback, and some time the "Disk Management tool" can see my HDD, but can't initialize it.
Alain Dionne さんによる
I want PassPort to answer the question. That's why I'm here.
Kelly さんによる
My passport WD was blinking and beeping. Now it's only blinking. Hasn't happened before. Truth is I barely ever use my computer anymore. After almost 30 years I'm almost totally out of Microsoft but I have lots of files & pictures there I'd prefer not losing.
Nick さんによる
i have similar issue here, the light to my passport is on but cant read the device? is it a cable issue?
huimeigege さんによる
4件以上のコメントを表示
