Hewlett-Packard began manufacturing personal laptop computers in 1993.
1726の回答 すべて表示
Original Screen Damaged & new screen's backlight won't work
Hi. I'm working on a student's HP Stream 11 note/netbook with a non-functioning screen. He came to me with the unit which would boot with the screen half light gray and half dark gray. He said he feared the unit was crushed in his backpack. I purchased a replacement screen, which the seller has told me is 100% compatible. The new screen works (when I'm shining my iPhone flashlight at it closely, but the backlight does not function. I've tried putting the old screen back on but now find nothing when I boot the unit. I've checked the connections at both monitor and motherboard, and everything seems to be good. The external video (HDMI) is functional and the keyboard, power button, and trackpad work. I assumed there was a fault in the video cable and tried flexing it at varying points at the transition from the lid to the base, with no change in display. Any ideas? I'm thinking of buying a new cable but want to be sure before spending the money and waiting. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
2回答
You probably got a faulty part, see if you can get a replacement from the original seller.
この回答は役に立ちましたか?
スコア 0
コメント:
Did this work? I have the same problem.
による
コメントを追加
Same thing just happened to me. After installing the new replacement no backlight not even with the old one
この回答は役に立ちましたか?
スコア 0
コメント:
# Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)
による
コメントを追加
回答を追加する
Andrew さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 468
