front of iPod hot after replacing battery
I replaced the battery in my iPod classic but as soon as I reconnected it to the front of the iPod, the front of the iPod became very hot. Should that happen?
paigeandersonmcdonald, always double check your work. Make sure the battery flex is properly seated. Be careful and double check the battery connector. It does have a tendency to break of the board. If it has come loose it is possible that you are shortening out the battery.
このアンサーは役に立ちましたか?
I am a total novice at working with electronics , so I'm not sure what I'm looking for but nothing appears loose and the wiring seems to be as far in as it can go. Still every time I retry the front still gets hot
Try with another new battery and see what happens. If it still gets hot you are having issues with the logic board.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 77
