My headphones don't work when I plug it into the jack?
My headphones work fine when I'm using them on my phone but for some reason they don't work when I plug it into my computer. How do I fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Alyssa Kristedja. Make sure that the drivers for your audio card are properly installed. Also, and I know this sounds stupid, but make sure that your headphones are properly plugged in to the headphone jack, not the mic etc. If that still won't work, check the bios to make sure that your audio card is properly initialized.
この回答は役に立ちましたか?
Assuming your headphones do in fact work, it might be that the device isn't recognizing them or just overrides them. If this is the case then you can manually connect and set your headphones as default through these steps..
For Windows 8 and 10 move your mouse to the top right of your screen and then straight down to bring up the charms sidebar.
a. Click settings
b. Click Control Panel.
c. Go to Hardware and Sound.
d. Click on Sound.
e. Right click your headphones in the pop-up window
f. Click connect
Hopefully this will set your headphones as the primary playback device. If this fails see the troubleshooting page mentioned above.
この回答は役に立ちましたか?
What if you dont see your headphones in that window???
i dont see the word connect as on option, so i just clicked ok but it still didn't work.
mine say they are working and that sound is being put through them and that they are the default device but no sound comes out. the headphones are fine in my phone, and the sound for the laptop works without the headphones. any ideas?
この回答は役に立ちましたか?
FOR MACBOOK AIR-
Im so happy that i figured this out
It might not be 100% accurate
1) Go to settings
2) Click Sound
3) Click output
4)plug your earbuds in
5) Click headphone port
6) slide the balance bar around, and it should work
(if you take your headphones out and it doesn’t make noise, slide the bar around again)
Hope this helped
この回答は役に立ちましたか?
This also works for Microsoft. Instead of clicking on sound, type in the search bar "sound" and click on the tab that says sound settings.
i need help y headphones wont work and i cant use them and they are brand new
この回答は役に立ちましたか?
i have tried to have mine fixed but they still wont work even by a prefessinal. does anyone know how to fix this?
what if your setting don't have a control panel
I'm having the same problem. I have a Dell laptop and so I've been taking with the reps. They gave me links to reinstall and I'm still having the same problem. The install links I got were: chip set, bios and the audio driver. I tried different headphones with no luck. I've looked online for a fix. One actually worked but it was only temporary. I'm wondering if my bluetooth devices are part of the problem even though they were never an issue before. I've never had this problem before and this one is a complete mystery. Even the reps at Dell are stumped. Their solution is to do a mail-in service.
この回答は役に立ちましたか?
On one phone, it didn’t work until I pushed hard on the plug and heard a click.
この回答は役に立ちましたか?
this was from last year
so i don’t know why i still have this on my new laptop
この回答は役に立ちましたか?
What the &&^& this ain't no answer I don't know what Go in on
この回答は役に立ちましたか?
Hey y'all you dumb
I have the same problem, everytime I plug in my headphones it says they aren’t plugged in, and these are brand new. Although, I tried restarting my Dell and now my headphones are working. I’m assuming you have to restart your computer every time you plug in your headphones to work, hopefully this works for you guys too
この回答は役に立ちましたか?
過去 24時間: 50
過去 7 日: 310
過去 30 日: 1,401
今までの合計 102,128
i have the same problem too and i dont no what to do
Allen McKee さんによる
I plugged the headphones into my computer and then restarted it. They worked after that.
David Gray さんによる
