Why won’t the car turn on?
My car won't turn on
Check both the remote control and the toy car to see if the batteries are properly in place. If they are, try replacing the batteries with a fresh set.
このアンサーは役に立ちましたか?
Some cars have batteries that must be replaced, whereas others are rechargeable. Charging may take a day or two, but depending on the car, it may be normal. If you do not have a charger, I recommend buying another, or if it is an older car, the chargers may only be sold on sites where you can buy a gently used charger that is inexpensive, and fits the make and model of your toy car. If these techniques do not work, I would suggest seeing a specialist to see if there is possibly something wrong with the remote, or the connection between the car and the remote.
I wish you the best,
Jolie Summers
このアンサーは役に立ちましたか?
No just the batteries, but also some cars have a black fuse or can be a relay that is bad.
Check the fuse with a tester both sides or pulled out and check the inside if is broken and replaced, and saw the relays.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 323
