Can Nexus 5X battery be put into Nexus 5?
What are the battery dimensions for Nexus 5X?
and Can it be put into a Nexus 5?
Dimensions of Nexus 5 battery are:
If you can and do use the other batery in your device you void your warenty. Thats to start, then there is the batery over heating and damaging your device. Lets not forget its ideas as this that start fires in which folks die. You have been warned.
このアンサーは役に立ちましたか?
Thanks for that.
I kind of did my measurements by capturing images from the net of the real size and watching Nexus 5x teardown videos. I verified the same procedure with my Nexus 5.
I found that the Nexus 5x battery is around 70mm in length whereas the nexus 5 battery is 60mm. So no luck, this difference cannot be accommodated.
Will now go and purchase a Nexus 5 battery itself.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,172
