メインコンテンツにスキップ
Huawei Mate 7(Huawei Ascend Mate 7とも呼ばれる)は、2014年10月に発売されたファーウェイ製のAndroidスマートフォンである。機種はMT7-TL00、MT7-L09、MT7-TL10、MT7-CL00。
19回答 すべてを表示
Why they can't hear me during a call
During a call, i can hear the person on the other line but they can't hear me. If i use the loud speaker mode or connect a head phone they will be able to hear me then. I already tried to restart the phone and even tried to reset it but still don't work. I wonder because I never dropped it and the phone is just a year old. So please help me. Thank you and I look forward to the help you can give.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
14 件のコメント
I also have this problem
さんによる
I also have the same problem
さんによる
I also have this problem and phone has been back to repair centre twice but same problem again!!!!
さんによる
I also have same problem
さんによる
I’m having the same problem with my p smart
さんによる
9件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
Hi @ toni_alison,
Check the suggestions in the Chosen Solution in this link and see if they help, especially regarding the voice inlet hole being blocked
The information is relevant, except for the phone make and model of course ;-)
No One can Hear Me... HELP!?!?!!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
My wife had this trubble, it was from a small amount of rain water that got into the microphone and killed it. The fix is to take the device apart, desoder the microphone, soder in a new microphone and put the device back to gather. HTC refused to honor the warenty then they voided the warenty wich forced me to fix it after they charged us $147.97 just for the microphone, the phone was only a $65 device. My advice, save the trubble, put it in the bone yard and enjoy a new device.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Sounds to me like it's an internal mic problem
さんによる
I found problem of mic
Go your phone's setting and go sound and search sound enhancement and turn off besloudness
Because I fix problem of my mobile to use it
さんによる
コメントを追加
hi. i had the same problem and got new phone because mine was under warranty. mine had the problem with the noise cancelation microphone which is near the headphone jack. The person on the other line could't hear me when i used the loud speaker mode, only in normal mode. So if you have warranty with your phone go with it and they will fix it or will replace it. Mine was replace it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is the phone under warranty? If so, you can take it to the service center of the manufacturer since Huawei puts much attention on product quality and customer's satisfaction.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My mobile is honor 10 lite
And I'm able to listen who called me
But they don't
What should I do
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
use a headphone or earphone , your microphone could be the issue
さんによる
@Famis Kadiro This is a wonderful suggestion....THANK YOU SO MUCH...Obviously my mic is playing up, but when I put my earphone in and phoned someone they could hear me. However, the recorder still isn't working, but I can cope with that as long as people can hear when I ring them..YO!!! thank you again.
さんによる
コメントを追加
回答を追加する
Venus Gacad さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 63,638
