メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
797回答 すべてを表示
Why won't my iPod hold a charge or sync?
My iPod worked perfectly for years...then I dropped it. It broke in half at the seam. I squished it back together and it worked fine. This happened about 4 times. Then I dropped it again. It split in half and this time a little piece of gray plastic fell out. I shoved it where I thought it should go and closed it back up. Only this time it didn't work. The words and picture on the screen were broken up and the blacklight dimmmed then went out. I thought it was gone for good until I got home and plugged it into my wall charger and it booted back up like nothing was wrong. But when I unplugged it everything died. When I plug into the computer it says "very low battery. please wait." But never charges or syncs.
Is the battery just blown or is it a more serious problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
It also works just fine when it's plugged into my car charger/player.
さんによる
コメントを追加
2件の回答
ベストアンサー
Just to answer this old question. If it works with it plugged in but does not charge, or quits working when unplugged, replace the battery. Start with the obvious things first, then look for the more complicated and expensive, like a logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would say is the same as this issue: usb device not recognized when plugged into computer
I'm betting for the logic board... but not a 100% sure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Esther Hamilton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,556
