メインコンテンツにスキップ
Staples light-duty electric pencil sharpener, model no. 34462.
4回答 すべてを表示
Sharpener keeps running even with no pencil inserted?
I have the opposite issue from a lot of people where their sharpeners won't run. Ours runs constantly, whether there's a pencil in it or not! To make it stop, we have to open the shavings drawer to release the switch that keeps the sharpener from operating when it's not there. I've tapped the sharpener vigorously and blown any shavings and debris out - everything I could see from outside the sharpener, down the bore hole and from what's accessible when the shavings drawer is removed, but it still runs continuously whenever connected to the wall plug.
I'm about to do an exploratory dissasembly, but I'm still wondering: what might be causing this? A problem with the insertion sensor? Is there anything well-known?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I don't know, It happened at school! But, I don't know seriously.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Gregory Samson,
You are correct. issue coming from the sensor. Check the wires of sensor and This guide will help you to fix the fault your self.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Gregory Samson さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 119
今までの合計 7,230
