メインコンテンツにスキップ
Krups single trigger coffee grinder identified as style F203.
How do I remove the blades? (Can't pull them off!)
Hi,
My grinder is not similar to the ones in the instructions. It's the same model, but it looks different inside. The blades are fasten with something that looks like a plastic nut on top. I´ve tried pulling on the blades, but it doesen´t seem to work. I´ve also tried to undo the nut, my tools are causing damage to the nut.
Do anyone know if this is a nut, or pulling harder is the solution? And if so, do anyone know if it is a right or left threaded nut (normal or lynx)?
My problem with the grinder is that the blades wont turn. The motor is working, but of some reason, either the rotor in the motor or the blade assy is stuck.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
3 件のコメント
Thanks for the answer! I got to the motor now, and the upper bearing is seized. As it's clearly cause of rust, this is my own fault. A few times I have used water to clean it, and the gasket on the shaft wasn't enough to stop penetration to the motor.
I guess there is no chance of saving it, but I will play with it some more and see what happens. Do anyone know how to disassemble the motor? I have removed the bolts, but the bearings are holding the upper and lower parts together (shrink fit?)
さんによる
I have the same problem. Did you figure out the problem?
さんによる
I have a similar problem, but a very old Krups with a pointy plastic nut on the blade, which I really can't get a grip on, even with vice grips, because of the taper.
I have tried to hold the shaft at the bottom, but the flat head screw groove is very shallow, and when I try to hold it in place, the screwdriver slips. Any suggestions?
Thanks!
さんによる
コメントを追加
7件の回答
ベストアンサー
Very simple: there is a slot through the bottom plate that is hidden under the product label. Take the label off, and the slot will be visible. This is a window that gives you access to the screw at the bottom of the engine shaft. Put a flat screwdriver head in the window and rotate the blades until the screwdriver sits in the slot of the shaft screw. Now keep the shaft steady and rotate the blade to unscrew. No need to take the bottom plate apart. It is a pain in the neck, and you will almost certainly break the latches that hold the bottom plate in place.
このアンサーは役に立ちましたか?
スコア 11
10 件のコメント:
This works like a charm.
さんによる
This fix for a Krupp F203 jammed blade works. First My wife threw it in the trash, I Googled the fix found this fix, Peel bottom sticker, I tried first a small screw driver that fit, small driver couldn’t get the torque. Screw That ! Get a bigger one and whaller out the slot, turn silver screw counter clockwise mine took 5-6 turns it loosed the blade. It now works like new I didn’t bother replacing the label
さんによる
Briliant! This really works, hard work but managed to turn the screw. Hard work also getting the label off. I threw away the previous grinder with same fault. I now know how to fix it. Thanks.
さんによる
When I removed the label (carefully so I could replace it), I could not get the screw head slot to line up with the slot in the plastic because the motor was frozen. So I drilled a hole through the plastic slot, big enough to match the diameter of the screw head. I could then use a large screw driver to turn the screw. I went ahead and held the blade (actually the gray plastic wings attached to the blade) and turned the bottom screw until the blades came off (maybe 8-10 turns). I plugged it back in, and it worked smoothly. I think just turning the screw loosened whatever was stuck. I screwed the blades back on, replaced the label and it works like new!
さんによる
My grinder (F408) has a screw in the bottom that holds the lid that hides the cable. No need to remove the label. Under the lid, I forced a screwdriver through the tiny slot to reach the shaft. Then I unscrewed the blade. Thanks for the guidance!
I was surprised to find out that the blade has no edge. My intention was to replace it to have a more homogenous grain but it looks like this is not the solution. Any ideas?
さんによる
5件以上のコメントを表示
コメントを追加
The blade is right hand threaded onto the motor shaft. If the motor is running, I can't understand why the blade is stationary unless the threads are stripped. That would seem unlikely though. If you are trying to remove the blade by twisting the blade's plastic hub, it probably will break before the blade is loosened. (Have you have removed the bottom of the grinder to access the slot in the end of the motor shaft ?) By inserting a screwdriver in the slot you can keep the armature stationary while you unscrew the blade. Then (with a rag for padding) the blade can be unscrewed (with a bit of effort). If the armature isn't turning when you are trying to remove the blade (and you haven't removed the base to access the slot), then the motor is probably frozen. Time to spend $20 on a new grinder. Also, even if you get it apart, I don't think there are any serviceable parts inside.
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
I removed the blade as stated and found that the blade was frozen due to a buildup of ground material around the blade plastic hub, and also around the shaft and inside the bearing support below the shaft threads that the blade hub fits down into. I cleaned these areas very well, blade with water and a tooth brush, the shaft and bearing support with a paper towel wrapped small screw driver. Tested the unit with the blade off! Bingo! Screwed the blade back on and I'm back grinding!
さんによる
Very helpful! I had no slot under the label and just drilled a whole (center of bottom opposite the center of the blade on the other side). The screw was right underneath and the replacement worked smoothly from there on :-)
さんによる
コメントを追加
Hello,
I had the same problem. Yes, remove the factory silver label/sticker from the bottom (be gentle, it is still possible to slowly remove it without damaging it, so when you put it back it looks decent again). You’ll find a slot with a visible metal screw-head-like-shaped thing , so you can insert a screwdriver there and hold it firm while turning the blade counter clockwise on the other side of your grinder. Now, I wanted to remove some water that got under the grinding metal bowl last night, so I looked closer at the center of the rotating core and depressed black plastic latches using thin plastic material (I used a small rectangular piece of a clear plastic form salad/spinach container from my local grocery store-worked well and didn't scratch any surface). Then I was able to shake out the metal bowl and voila. I was actually surprised that there was another plastic bottom there, so there was a hope that the water did not get down to the electric motor. Yeah !!! I wiped the whole thing, dried it and assembled together. Remember, do not attempt to use running water to clean the grinding compartment after, e.g., grinding spices, herbs etc. Just wipe it with a clean dry or damp cloth. Anyway, the grinder still works, so no water damage or danger of electrocution.
I was wondering how to effectively remove the bottom part of the grinder, there is four sets of latches there, but I was not able to loosen them, even if inserting three screwdrivers there at the same time. Has anyone tried? I hate to scratch or damage those kind of things for esthetic reasons, so it would be good to know exactly how it is supposed to be removed. I hope this helps, good luck to all.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I just fixed my 30 yr old Krups mill. Removed the blades as mentioned in previous posts, took of the bottom (two screws), cleaned all of the grinding dust then oiled the moving parts with clock oil. Clock oil lasts a long, long time. Reassemble and it works like a champ!! Just needed some cleaning and oil. Sure don’t make ‘em like they used to!!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have a Type 203. No F, no a, just a serial number 0603. I have no bottom label, The information on the bottom is stamped into the bottom. No holes other than for two phillips head screws holding the bottom on. Inside the grinding compartment, the blade is held on with a conically shaped hex nut, plastic. It is a 120v, unit, no doubt for North America.
There is absolutely no information on this specific unit on the web. Krups doesn't even seem to know it exists.
My problem is the blade edges are pretty beat up after almost 30 years, so I would like to either replace, or refile them. The grinding seems to be inconsistent as a result, with many larger grinds and some almost powdery grinds each time. Motor works perfectly.
The blade itself is actually inset into the bottom of the conical hex nut, so turning it while holding the blade will not work, and will result in damage to either the blade, the nut, or both.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The motor on my grinder functions, but the blade no longer rotates. In fact it can be pulled away from the end of the shaft easily. There appear to be strands of plastic from the blade boss/hub still attached to the grooves in the metal shaft. Perhaps I can refit the blade using epoxy resin.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are there replacement blades available? I have a Krups and the blade is there and the nut is there but the plastic piece that attaches everything is missing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hallvard さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 39
過去 30 日: 262
今までの合計 30,730
