メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone can't turn on after replacing battery
See a few weeks ago, my cousin gave me his Iphone 5 hoping that I could fix it. He apparently dropped it in water and cant turn it on. So I put it inside a container with rice for a few days and when I tested it, it worked... for a few minuites before it died and I couldnt do anything. So I bought a battery from ebay and replaced it. I double checked all the connections and charged it. A few hours later...I checked and it still wont turn on. So any ideas on how to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Daaamn. You know how to disassembly phone, but after phone get water damaged You put him in to rise ?
さんによる
Um... well if it worked with my Ipod its should work again
さんによる
コメントを追加
3件の回答
ベストアンサー
Well, you could try the dock connector. Before you go for thebU2IC
iPhone 5のLightningコネクターとヘッドホンジャックの交換
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Um I charged it and it became really hot any other ideas?
さんによる
So it did come back on? After what?
さんによる
コメントを追加
Corrosion.
You only way to MAYBE fix this, it is by using isopropyl alcohol on corrosion on motherboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Fred Lee, "I charged it and it became really hot " your rice obviously did not work. Heat = short circuit. Next time skip the rice. It will not prevent corrosion nor will it fix the phone, it is a misleading myth. totally agree on this with Phonetech93 on this one. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. You also do not want to try to charge it any further. The next thing to do is to clean it. Disassemble your phone using these guides. Once it is disassembled remove the EMI shields from the logic board. After that you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for a 3G all the points are still pertinent to your phone. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Water damage is the hardest to diagnose since virtually any part may have short circuited.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Fred Lee さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 115
