メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
Repair guides and support for the 3rd generation of Chevy G-Series vans. Similar vans were produced under the GMC brand. Both used suspension and steering parts from GM's C-series pickup trucks.
14の回答 すべてを表示
Why is my g20 6.2 diesel getting stuck at 25mph(wot)
My 1985 Chevy g20 6.2 diesel it's consistently not letting me go past 25mph unless I go down a hill it's then shifting into the gear after 25 mph and I can drive it in that gear the whole way to wot 85mph. But obviously if I come to a stop. I will be stuck at 25mph. Its a 700r4 with 198k always maintained as far as fluids and what not. Took across country no probable but when I returned my instrument cluster shorted out had to replace the board on it . It still blows fuses but not as instantly as it was if I'm setting still I can throw a fuse in the gauge fuse opening and see how much fuel I have however when I start it up and put it in reverse of turn the wheel it blows the fuse. Not sure if there's a relation to that and the getting stuck at 25mph but thought I'd add that in there. Please help thank you!
Update (10/16/2015)
So in a more simple way it is that it is stuck at 25 on flat roads and up hills wide open but if I have enough of a hill to make my van drift catch 36mph til shift into the next gear and I can hold that gear as long as no cars or stops get in my way but around here misty city so it's always less then 36mph.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
Sounds like a faulty transmission... I recommend taking it to a certified mechanic or machine shop like Aamco (not sure if that specific mechanic is near you, though), have them give it a good diagnosis.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
overlandwill9 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 209
