メインコンテンツにスキップ
ハードドライブもしくはハードディスクに関する修理情報です。ハードドライブは磁気データ記憶装置です。 低コストでデータ密度が高いため、ほとんどのデスクトップ、ラップトップ、およびサーバーで使用されています。
143回答 すべてを表示
Adapter cable to connect a SATA HD?
Wondering if there is an adapter cable that can be hooked into firewire or USB to power-up and read an external SATA drive (one removed from another failed PowerBook or MacBook for data recovery)
Perhaps a pin-out diagram to make one up would do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
what you're looking for is one of these universal USB 2.0 drive adapters - you can find other manufacturers too, not just this particular brand
FAR more versatile than an external firewire enclosure. a must-have tool for anyone who often takes apart computers and needs to transfer data between drives. - inexpensive and can interface to many different kinds and physical sizes of drives.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
These things are great. I used one when I had to clone my hard drive, and it was simple dimple. I have a couple of enclosures, but those work much better when you're making a permanent home for a drive.
さんによる
The adapters are indeed very helpful, but it's worth noting that if you're moving a lot of data around or wiping a drive, a firewire hard drive enclosure is a lot faster.
さんによる
コメントを追加
You need a hard drive enclosure, you cant just connect it straight to the firewire port as there is complex circuitry involved. You can find one here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks everyone, I think the question is answered.
Merry Christmas to all... I'll see if there is still time for Santa to dredge up an adapter cable for me.
D
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Ok... Thanks for the info. However, are you sure this will work for a HD from a MacBook? The HD is a Seagate Momentus 5400.3 120GB. I bought a similar adapter, a Vantec, and the connectors did not fit the HD. Has anyone used the product on the link above for a Mac Laptop HD?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The seagate is only a sata disk (ok, ncq - but the connector is the same). i can read, write and boot the connected devices. look out for a set with sata support.
さんによる
コメントを追加
回答を追加する
damaclac さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 7
今までの合計 3,296
