Why does my tablet have difficulty connecting to the Wi-Fi?
My Tablet keeps jumping on and off, but not connecting to the Wi-Fi, and my patience is worn out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You have several ways to be out of the woods. Select a network and then re-enter the password or select other Wi-Fi signal to see if it works. Otherwise, try to move your location to see if your tablet can connect to a stonger signal elsewhere. Remember, sometimes a wall or, even buildings, can be your enemies.
このアンサーは役に立ちましたか?
try to backup your device the wipe it by pressing the home button and the volume button up simultaneously
select factory wipe and reboot the device, try to connect with wifi it should connect then restore your infos
if it does not connect and that you are confident to open the device cheick for wifi cable if it s is connected
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 130
