My ps4 keeps on ejecting my discs then beeps constantly
hi when i put a disc into my ps4 it keeps ejecting it then beeps constantly does any1 know how to fix it thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This is a known issue with PS4's. It happens to a lot of them. the good news is that it is usually fixable. You can first make sure that it's sitting on a flat surface with nothing under it or on top of it. Sometimes removing the rubber feet in the middle of the bottom side of the console will help.
I hope this helps.
このアンサーは役に立ちましたか?
There is a screw that's accessible through the HDD slot that controls manual ejection. Try tightening that screw, it's the only related screw you can get to without voiding the warranty.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 2,938
1件のコメント
Just checking to see if you've gotten this fixed or if you still need help.
TronicsFix さんによる
