メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Touchscreen freezes after fall
Hi,
I own a small repair shop in Amsterdam and recently I came across several iphone 6 with the following issue:
Customer dropped the phone the screen is broken and in some cases not but it freezes and becomes unresponsive after short while after start. It might be completely operational for a few minute at some point it just gets stuck. The phone doesnt get hot or anything.
My assumption is that something gets damaged on the logic board because of the shatter damage from the fall but I didn't find a way to test it.
New screens are 100% working because if I use them on another iphone 6, no problem.
Did anyone else have this same issue? Any possible solution or just a waste of time?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
I have the same problem
after you change the screen, parts iFixit, my phone works perfectly, but after 5 or 10 minutes of waking up the phone reacts. Long press on a button "home + power" and reboot normally my phone all over again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this problem as well, any solutions? Soft reset doesn't help. Factory reset and set up as new phone doesn't help. Cleaning connectors with iso alcohol didn't help.
Software updated normally. I've tried several known working screens but they only function for a few minutes before freezing and not always working from boot up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Solved....in my case anyway. Long screws in wrong holes on connector shield. Trace damage on mobo to centre and bottom right screw holes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes I did I drop my phone on the ground and my phone froze and I pushed the power button it didn’t freeze again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maximus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 3,952
