My Literider won't move?
No matter what I do, the Literider won't move. The wheels are not rotating. How can i fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First, make sure that the wheels are not locked. Make sure that the switches on the front wheels are down, and the switches on the back wheels are up. If the wheels are unlocked, but still not moving, try cleaning them. They may have sand or dirt obstructing their movement. If neither of these are the problem, you will most likely have to replace the wheel. For the back wheels, you will have to remove the caps holding the wheel on by prying them off. The front wheels will have to be pried off as well. After removing the front wheels, new ones can be put on by sliding them on and applying pressure until you hear a click. Here is a link to the troubleshooting page, and here is a link to the wheel replacement guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
