メインコンテンツにスキップ
error message "Restart computer' is repeating
After installing a new hard drive, great step by step explanation on ifixit, I installed the OS version 10.4.7 which the computer came with.
Than I installed the OS X Leopard and connected with the time machine to restore the backup files.
This took multiple hours and this morning I got the message restore complete please reboot. which I did but now after rebooting the gray screen turns to a dark gray screen and the message in a black box appears "Restart computer by holding down the button..." Unfortunately everytime I do this I end up with the same screen.
I run disk utilities and repair disk, but can't detect any problems.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Disconnect the external and try. Start in "Safe Mode" by holding down the "shift key". If successful download the 10.5 updates and get it to 10.5.8.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
さんによる
Thank you for your help. I discovered that we actually upgraded to Snow Leopard and to restore files from the time machine it has to be with the same operating system as it was saved as a back up.
Now the imac is up and running again and everything was saved.
さんによる
If you upgraded to Snow Leopard, you have an Intel machine, not a G5.
さんによる
コメントを追加
回答を追加する
Uschi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 1,659
