メインコンテンツにスキップ
iPod Shuffleの全モデル用完全修理ガイドです。これらのデバイスの修理の多くは難易度が高く、接着剤に対応しなければなりません。
162回答 すべてを表示
iPod shuffle, 2nd Gen. 1 Gb- No green light, no power- why?
Please advise on how to find a battery and install- Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Nick, users should generally use our guides for repair instructions, not teardowns. "Teardowns provide a look inside a device and should not be used as disassembly instructions." We often omit key disassembly steps for the sake of brevity, in order to get onto describing the cooler parts of the device.
However butrpg, as can be seen in this teardown, the battery in the iPod shuffle 2nd Gen is soldered to the logic board. Thus fixing it would not be simple unless you or a friend had some soldering skills. We do not yet have a battery replacement guide for your iPod, if you do replace the battery though, please come back and show us how you did it!
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thank you Taylor- the teardown is extremely helpful and I would love to do it, but where do I find the battery?
さんによる
In that guide, the battery can be seen most clearly in steps 8, 9, and 10. It is the white packet with an orange border that flips out from the logic board. If you meant where to buy a replacement battery, unfortunately iFixit does not sell that part. You might find what you're looking for with this ebay search though. Please keep in mind that even though it's a reasonable starting point, the teardown is not intended to be used as disassembly instructions, and doing so may result in permanently damaging your device. If you still decide to go forward with the repair, it looks to me like it's probably only 2 quick solders. Good luck!
さんによる
I found the battery on Digi Express for $15.
さんによる
I can in no way vouch for the quality of any battery provider, but I would point out that two of the four results on the ebay search I linked have batteries for $4.49 - $5.45 instead of $15. :)
さんによる
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
butrpg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,195
