Need a replacement screen
I need to replace my screen. I just want to make sure I buy the correct replacement screen. Thanks
You have one of the original 2006 Macbook Core Duo (i.e. NOT Core 2 Duo)?
As far as I know the LCD panel itself is the same between 2006 to 2008. There are at least 3 makers of the screens (I think Samsung, LG, and someone else) but they are interchangeable. I buy new displays from a company in BC and I usually end up getting Samsung displays. The processs to change them is a bit involved... probably not for those who have never worked on Macbooks before.
このアンサーは役に立ちましたか?
Here is the part and the guide to change it. You can do the bare display too, but iFixit doesn't have a guide for it on this model.
このアンサーは役に立ちましたか?
Specifically, this is the guide to replace your display.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,056
6 件のコメント
please tell us exactly which machine you have
mayer さんによる
I have a macboodk Model A1181.
Joan さんによる
Are you replacing the whole screen assembly with the casing (Apple logo on back) or are you going to disassemble the assembly and replace just the LCD panel?
dadioh さんによる
I would do whatever is easiest. I didn't know replacing just the LCD panel was an option.
Joan さんによる
I found a screen on ebay but it said it was a CCFL backlight screen, NOT LED type screen. I just need to find out if this screen will work on my macbbook.
Joan さんによる
1以上のコメントを表示
