One of the USB ports is damaged
Shortly after the warranty expired on this laptop, one of the USB ports would not work. I brought it to Apple and was told the port is damaged. I'd like to know if if you could repair it.
Absolutely! This port should be located on a PCB board that also contains the audio port and magsafe connection. Should just be a simple part swap.
このアンサーは役に立ちましたか?
where can I purchase the part for the damaged USB Port?
Look on Ebay,Amazon, Ebay you will find just about everything.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 103
