メインコンテンツにスキップ
The Kenmore Direct Drive is a washing machine by Kenmore.
58回答 すべてを表示
washer won't drain, spin, or rinse, but it fills and agitates
washer fills with water and agitates but will not go to next step, draining, spinning, and rinsing. I have never had any problem of any kind with this machine. I just did a load 2 days ago, there was no different sound and laundry came out great.
It is a Kenmore 110 series top load. I hope you can help me.!! It is Saturday and I have a load sitting in water.!
Thank you,
Barry.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
barry, it is possible that you have defective lid switch. If so, the washer will not spin or pump the water out. The other things that can cause this is a defective or clogged drain pump. We would need a the model and serial number to give you more detailed instructions.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It was the lid switch, I was able to get it to work till I can go to the store on Monday. My clothes are now in the dryer.
You were bang on the money.!
Thank you,very much,
Barry
さんによる
You are welcome and best of luck to you.
さんによる
コメントを追加
回答を追加する
barry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 4,252
