メインコンテンツにスキップ
My logitech headset H600 is not working anymore
i bought my logitech wireless headset last nov 2014,now its not working anymore,when i charge it,the orange button is on,but if i turn it on,red is blinking,no green light,i was thinking im gonna replace the battery but im worried its not the battery thats a problem,and ill end up wasting money again,please whoever who has knowledge of it can you share it,thanks i appreciate all the input.
Sophie
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Led very dim, not charging. Turning on and off 7 times seems to have restarted them, charging now.
さんによる
コメントを追加
5件の回答
最も参考になった回答
In most cases the battery is still ok, when this problem occurs. It seems that the logic board just refuses to charge the battery. You may try to trick it by switching on and off the headsets right after you plug them to charge (about 10 times will do) I am not sure how, but i think it is like a reset thing for the logic board.
このアンサーは役に立ちましたか?
スコア 6
4 件のコメント:
The refusal to re-charge happened to me when I left the headset turned on and drained the battery totally. I plugged in and then unplugged the USB mini. As soon as I plugged in the cord, I began clicking the power switch back and forth. After six or seven times, the battery began charging. I still do not know if this worked, but the charging light is now blinking.
さんによる
dinu, thanks very much, my headset came to life again due to your help. Thanks again.
さんによる
Switching on-off 4/5 times after connecting the device to an USB port did the trick. It worked like a reset. Thanks a lot.
さんによる
Thank you Dinu. You're trick worked with my headset and it works completely fine now.
さんによる
コメントを追加
Hello there, I had the same problem, I just took out the USB and put it back again then some how it worked. Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
That fixed it. Thanks so much!
さんによる
コメントを追加
In my case with the rapid blinking green light, I eventually noticed that one of the buttons on the headset was jammed down and I had to pluck it loose with a knife. I’m still trying to reconnect the headset, but I noticed the rapid blinking has seemingly stopped.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Man I love you! You just fixed my headset <3
さんによる
コメントを追加
I have the new H-600 with the white ring, and I tried this and it did not fix my issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It didnt fix mine either
さんによる
コメントを追加
Have you tried contacting the manufacturer? You should be able to get warranty service under the two year warranty that Logitech offers.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sophie さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 60
今までの合計 8,792
