Why won't my device turn on?
Tablet is unresponsive when I press the power button.
Generally, this question is caused by broken battery or broken button. Try to connect it to any device and see if there is any response. If yes, there may be some problem on your power button, else, your battery should take responsibility. You can check the Replacement Guide part and follow the step to replace your broken part.
このアンサーは役に立ちましたか?
I have a new iview laptop will not turn on at all
このアンサーは役に立ちましたか?
It’s brand new just started it up and then started dL ing and then turned off and will not turn on
i have a iview tablet it turn but only where its says reboot please help me
このアンサーは役に立ちましたか?
The iview was just fully clean by resetting it
but it’s not showing anything after the iview logo. The screen remains greyish
このアンサーは役に立ちましたか?
What todo with this I had to reset it because
I forgot password
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 1,883
2 件のコメント
730TPC if i turn on is shown searching always never allow me to turn off. or seen anything on screen unless iview
Nuhu Isa さんによる
This iview will not turn on I bought it for my daughter for Christmas so I decided to check it out it will not turn on
Kelly Haywood さんによる
