Update done and it gone off and won't turn back on
I done a systems update on my Acer A3, it switched off straight away and now won't turn back on, please help
This sounds like an operating system boot loader problem. When a device turns on, it gives permission to the operating system (in this case, Android) for a very small number of devices, such as the CPU and the power supply. As the operating system boots up, it requests and receives more and more permissions. When the device does not get boot loader permissions though, it cannot boot. This is something that will have to be resolved through Acer customer support. Hope this helps.
このアンサーは役に立ちましたか?
The tutorial is :
> http://acer-club.fr/viewtopic.php?f=227&... ==> [TUTO] Unlock Bootloader + Flasher CWM + Root [A3-A10]
__________________________________________________________________________________________________________________
> http://acer-club.fr/viewtopic.php?f=227&... ==> [TUTO]Unbrick/flasher le dernier firmware JB [A3-A10/A3-A11]
___________________________________________________________________________________________________________________
> & all in ==> http://forum.xda-developers.com/android/...
> & http://forum.xda-developers.com/showthre...
____________________________________________________________________________________________________________________
A3-A10 | JB | http://is.gd/fa10_42 | c663e76b16a930f10dff84510a79b740 | AV052_A3-A10_RV05RC01_WW_GEN1
| A3-A10 | KK | http://cutt.us/gwSU | a8927856a6d655adb2ea9d4807fc63be | AV0K0_A3-A10_RV05RC03_WW_GEN1
| A3-A11 | JB | http://is.gd/fa11_42 | 0d828c175073896adef35015c03617c7 | AV052_A3-A11_RV01RC12_WW_GEN1
| A3-A11 | KK | http://cutt.us/gJzLe | b1f610a1b07b3c0b120d103318508bca | AV0K0_A3-A11_RV04RC05_WW_GEN1
| A3-A11 | KK | http://cutt.us/jjOp | 59705bb7d9bb1d7530fee641aeaa5bbf | AV0K0_A3-A11_RV04RC07_WW_GEN1
♥ Good Luck ♥
このアンサーは役に立ちましたか?
it's too easy Guys .
-If you are unable to start the process for your tablet does not answer the Preloader mode, you need to remove the back cover and disconnect the battery and start the tutorial battery disconnected.
Once the tutorial finished, reconnect the battery. put in charge 10 min and then attempt to restart.
1- remove the back cover.
2- disconnect the battery.
3- reconnect the battery.
4- put in charge 10 min.
5- attempt to restart.
GOOD LUCK
[RYAN KHENNOUCI]
このアンサーは役に立ちましたか?
Please make antoher guide the website is not available anymore
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 554
