What is the typical fans speed & max CPU temp.
I want to upgrade my HD on iMac 27" mid 2010 to a western Digital Black 4G.
Which will mean I will need a software fan control for my Mac.
It would be really nice to know the thresholds for fan speeds and max tentative so I can set up my fans and temps on the side of caution.
Many thanks in advance.
Update (10/06/2015)
Hi Dan thank you so much for you reply.
In responce to your question my drive is:
I was not aware there is a hardware solution for fan control for this hard drive and my 27inch imac mid 2010?
Awesome and Thanks in Advances - Kindly Simon
この質問は役に立ちましたか?
4 件のコメント
Can you give us the exact drive you are planning on putting in. Depending on what your system currently has you maybe OK, or at worse just need a different temp sensor cable that works with the drive you are planning on using.
Dan さんによる
I don't recommend fan control software when a hardware solution is available.
Dan さんによる
Dear Dan
You are truly awesome. Thank you so much for taking the time to help me. Greatly appreciated. I shall order my parts now once and again Thank you !
Kindly Simon
Simon Newbound さんによる
Let us know how it all turns out - Enjoy!
Dan さんによる
