メインコンテンツにスキップ
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52回答 すべてを表示
Flash lens burned out, how do I fix it?
The built in flash rises up but the light does not turn on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If the camera battery is dying or faulty, it can cause problems with your flash. Remove your camera battery and charge it fully. If the problem persists, you might need to replace your battery. If your flash is burned out, you will need to replace it. Check out this troubleshooting page for more information.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
No reply on HOW to fix it.
さんによる
Hi @eyecue ,
If you click on the troubleshooting link above and then scroll down to the flash burned out section on the page there is a link to a guide that shows how to dis-assemble the camera so that access the flash bulb is possible so that it can be replaced. There are also some useful comments at the bottom of the guide.
Here's a direct link
Canon EOS Rebel T3i Top Casing Replacement
さんによる
コメントを追加
回答を追加する
Tori Clayton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 3,960
