メインコンテンツにスキップ
Released in 2010 and 2011, the G73 is a series of gaming laptops from Asus. Model numbers include G73JH, G73JW, and G73SW. All versions use an Intel Core processor and dedicated graphics card.
17回答 すべてを表示
laptop powers up but dead screen
My asus G73s powers up but I have no screen stays black
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I had this same problem. I already tried turning on without any hard disk and switching each ram slot. But still doesn't solve. If the case problem was caused by dead gpu, but why when I turned on while plugging my external rgb keyboard/mouse they doesn't turned on/lights up. Does dead gpu also causing that? Or it could be something else. Thanks before
さんによる
コメントを追加
最も参考になった回答
Johnny, attach an external monitor and see if that display properly. If it does you most likely have a bad LCD. If it does not than you could have a while lot of different issues, like a bad GPU, bad BIOS etc. Start with the monitor and let us know what you get.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks
I did but it doesn't work and we disconnect every thing except the VGA and MB and it was same issue.
さんによる
Please, how do you power-up directly on an external monitor (on an ASUS G73S) with the internal monitor not working?
Thank you !
さんによる
コメントを追加
回答を追加する
Johnny さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 2,389
