メインコンテンツにスキップ
The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
16回答 すべてを表示
wifi doesn't work on padfone 2
Hello! after i have bricked my telephone, i was able to repair it, and i re install the lastest firmware, all works, but no wifi!!!! i think it's a software's problem.. it see the networks, i try to connect, but nothing, only "connecting" , and stop.. how can i solve it? i have changed some firware, uffical and rom.. re install the wifi driver? but how? thanks..
i attacched this screen for some informations..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
hvae you installed CyanogenMod (custom ROM)? which OS is currantly running on your phone ?
さんによる
4.4 official, no cyano, i tried other rom with 4.4 or 4.1.. but nothing
さんによる
コメントを追加
1 件の回答
Dear psycho91,
Wi-Fi TRX not functioning on your phone. that is the reason to get RSSI -200 (Ordinary Wi-Fi RSSI range is -20dbm to 120dbm) you will have to replace Wi-Fi + BT module on your logic board.
Vocabulary
RSSI means Received Signal Strength Indicator
TRX means Transceiver
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks, but i try in another house, and work, i went to mine and work... for now.. yesterday same problem.. don't connect!!! it's probably a software problem
さんによる
コメントを追加
回答を追加する
psycho91 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 7
今までの合計 448
