メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1232回答 すべてを表示
How can I fix the digitizer and screen?
I replaced the screen on this broke iphoone 5c. It now looks like the pictures above and is getting a little hot in the upper right corner (on the back where the digitizer and screen connects). I need some help on how to fix it.
Thanks,
David
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hi David! Check the cables of the lcd and the digitizer,if they are damaged.As i see from the pictures i believe you haven't connected the cables very well(i had a same situation with an iphone 5 the lcd cable was bent and not correctly connected to the mainboard). After unpluging and pluging again the cables power on the iphone before assembling it again.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
hey thanks for that insight. I tried the screen on another iphone 5c... it worked. I'm thinking there is an issue with the logic board. Does anybody have any insight on a specific part that could be switched on the logic board to fix the display/digitizer?
Thanks,
David Ogle
さんによる
コメントを追加
David, this can be caused by a bad digitizer connector. As you can see the connector lacks metal ends and this is what makes it a weak connector. It is easily possible to damage the connector by mis-aligning the digitizer connector
like this. Check the ends of the connector. The plastic of the connector has been compressed into the connector, causing it to flare out and preventing from making proper contact.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
oldturkey03, Thanks for that! I don't see any issues with the connectors. I'm going to post the pics in the 'answered'. Please take a look and tell me what you think...
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 396
