Salt Water Damage and LCD is Not Working
I want to ask if there's an available replacement LCD for GoPro Hero 4 SE or still can be repaired without replacing the LCD? My GoPro accidentally got wet from salt water. Please help. Thanks
borgyboi, the LCD assembly is available right here You do need to take care of the salt water damage as well. For that you will need to disassemble your GoPro and clean every part with sterile water and a brush first. Then follow that by a good cleaning with some high grade 90%+ isopropyl alcohol. If you do not clean it, your GoPro will end up with corrosion damage.
このアンサーは役に立ちましたか?
Actually, the LCD screen is totally black out but the GoPro is still working without the monitor behind it. Anyway, where can I buy this? Is it available in store or thru online only?
Thanks Lot! oldturkey
Contact ifixit directly on here
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 544
