Flash lens burned out, how do I fix it?
The built in flash rises up but the light does not turn on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the camera battery is dying or faulty, it can cause problems with your flash. Remove your camera battery and charge it fully. If the problem persists, you might need to replace your battery. If your flash is burned out, you will need to replace it. Check out this troubleshooting page for more information.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 105
