Camera won't turn on?
I keep pressing and holding the power button, but it won't turn on.
Try plugging your camera into the charger and ensure that the charger works. To check if the charger works, try using it on any other device that it is compatible with (microUSB is compatible with almost every electronic device). If the charger isn't working then your issue is with the charger. If the charger works and the camera still won't turn on, try to replace the power docking port.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 839
