Screen lights up, no audio and no pics on the screen?
My ipod stopped working today. lights up but doesnt do anything else. any ideas. im not very tech savy....
If you had it near moisture or water it may have damaged the logic board.
このアンサーは役に立ちましたか?
You can manually reset your device with the click wheel center and menu buttons pressed at the same time after unswitching the hold button on the bottom.
If that doesn't work use the iTunes software to reset the device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 831
