メインコンテンツにスキップ
The first generation of the executive car by Volvo known as the S80.
10回答 すべてを表示
makes a loud "BRRRRRRRing" sound when trying to start & doesn't start
Battery dead. Hooked up to charger. Try to start and a LOUD BRRRRRRR or Clucking sound comes from under the hood. Car will not start.
Put a charger on the thingy under the hood to jump start but didn't work. Battery itself is in the trunk. Should I have put the charger there instead?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thank you all soooo much. It has made what seemed to be a weird problem, much easier to understand and to not be so worried about some massive expense to fix it. Being uneducated about cars is worse for me, being female, because I seem to be at the mercy of too many mechanics. With your help, I've solved the problem with only the expense of a new battery. With Gratitude. Sharon
さんによる
コメントを追加
2件の回答
最も参考になった回答
Sharon not quite sure about the noise, but from what you are describing it is the starter solenoid making that noise. Recharge you battery and have it checked to see if it holds a charge. If a new battery does not fix that, check the starter itself. You can try to "hotwire" it to see if it works, most likely you will need to replace it.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
thank you! it is now all fixed. new battery took care of problem!!
さんによる
This noise is what is made when a weak battery does not have enough power to engage the starter gear far enough to mesh in the flex plate/ring gear/flywheel.
さんによる
コメントを追加
Has it been sitting there for a while? If it tries to turn over, then the battery is fine. When was the last time you replaced your plugs and wires? It seems like its the actual starter or some component thereof rather than the battery. Hope this helps
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
thank you. yes, it had been sitting a very long time. i tried to charge the battery with a trickle charger and it did try to start but kept making that crazy sound. a new battery cured it. sharon
さんによる
Glad to hear it. :) Happy halloween!
さんによる
コメントを追加
回答を追加する
Sharon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 317
