My Samsung fridge won't make any ice... Water comes fine
Water is coming out fine, but ice isnt being made at all.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'm not sure of where the water is coming out fine.
Cause 1
Freezer Temperature is Above 10 Degrees F (-12C)
If the freezer temperature is above 10 degrees Fahrenheit (-12C), the ice maker will not produce ice cubes efficiently. The freezer temperature should be set between 0 and 5 degrees Fahrenheit (-18 to -15C) for the ice maker to work properly. If the freezer temperature is too high, ensure that the condenser coils are clear of debris and the condenser fan is working properly. In addition, check to see if frost has accumulated on the evaporator coils. If the evaporator coils are frosted over, part of the defrost system has likely failed.
Cause 2
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Cause 3
Ice Maker Assembly
One component of the ice maker assembly might be defective. Since many of the ice maker components are not sold separately, you may need to purchase and replace the entire ice maker assembly. Before replacing the ice maker assembly, check the water inlet valve, water line, and fan. If none of these parts are at fault, and the freezer temperature is at least 15 degrees Fahrenheit, replace the ice maker assembly.
このアンサーは役に立ちましたか?
My ice maker has stopped making ice, too. It isn't iced up, the water is dispensing fine and the freezer temperature is set at 7F. I've pushed the reset button and heard the chime. Have waited more than 24 hrs. and still no ice. Any other suggestions? Thanks
Did you get your ice maker working? Having the same issue
Me too! Any fix?
Shane,
Very nice video. Thanks for the info.
Quetion; how long should we leave the fridge if forced defrost mode to clear the coils with out having to remove the built up ice?
このアンサーは役に立ちましたか?
Our Samsung freezer was providing water and very little ice. A new cheaper filter bought from Amazon didn’t work and clogged up in 3 weeks.. We replaced the filter with an OEM “Samsung branded” filter and was working better but still not much ice. I could hear the mechanism struggling to work..and noticed that there was frost all over the inside of the ice maker. I RAISED the temp from “0” to “3” degrees and it is performing way better.
このアンサーは役に立ちましたか?
過去 24時間: 10
過去 7 日: 71
過去 30 日: 368
今までの合計 28,769
1件のコメント
La Runce Moffett さんによる
