Glue for the plastic touch panel cover
GE Microwave Model# DVM1850DM1WW Ser# ZL900414B - Dec 2006. Plastic touch panel cover keeps coming off - what glue can I use at the edges to keep it on?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I used Scott's double-sided tape. The cover is not flush against the pushbuttons but it works much better than having it fall off several times a day.
このアンサーは役に立ちましたか?
I used a thin line of Gorilla Glue. Gently pulled back the panel 1/2 inch or so, cleaned edges with a thin sponge. Left it wet (that's how Gorilla Glue works). Used a q-tip to put the glue on. Taped it real tight with electrical tape long enough for the glue to cure. Removed the tape 24 hours later, works like a charm.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 6,546
1件のコメント
I contacted GE and they had no recommendation - see a service person!! Said glue might get hot. (Not satisfactory customer support for me!!) My service cotract says it's cosmetic and can't support - tried, but no glue recommendation - reffered me to GE. Does anyone know of a 'rubber' glue so the panel can be removed for access to the microswitches?
Jim LeTellier さんによる
