eMachines Desktop et1331g-05w Bad sectors what do I do
i have to press F1 key in order to start windows7 it says i have bad sectors what do i need to do? i want to keep my data!
Try using the fdisk utility of DOS. I have tried using this and it had saved me numerous hard drives in the past. It is pretty much straightforward on how to use it, although you might need a windows startup disk but if you have precious data then it might be worth to create one.
This article will show you how to use fdisk.
https://support.microsoft.com/en-us/kb/2...
Cheers!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 100
