Where can I buys a missing pour spout for this machine?
i got a used Starbucks Barista Espresso Machine and it is missing a pour spout. Can i buy it somewhere? or can i use it without it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
What you want is called a "portafilter", and there are several different versions that fit that machine, but anything that's a Saeco brand will work as they're all the same size (53mm). You can see most of the different options here:
http://www.partsguru.com/SaecoPortafilte...
...and if you Google the part numbers you should find other purchase options that might be cheaper.
このアンサーは役に立ちましたか?
Now this is an answer by someone that knows their coffee machines. Kudos.
A Rose by another name?
Here's a list of parts for your machine but I do not see a part named a spout. Could it be called something else? https://www.espressocare.com/products/st...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 130
